Snap sequences on timeline back to front
  • Snap sequences on timeline back to front
    I want to move 1 sequence to start where the other stops. How can I snap to do this.
    Can I type in at which frame a sequence should be positioned?
    Kind Regards,
    Morne
    Hello,
    For the time being it is not possible to snap layers in the time line. In the Layer menu there are options for adjusting the position of layers in the time line ( "Go to Begin", "Go to End", "Align Begin at Current" etc.) You can try and work with those and if you want to you can assign custom short cut keys to those commands. You can check Section X of the Manual.
    Best Regards,
    Jimmy
