There is one way to change the port number and that is via the command line option "--http_port". To set it to 80, for example, you'd use "--http_port=80". Depending on platform, you could add this option to the shortcut/script with which you start Pdplayer, or you could bind it to a hotkey, say, Alt+F1, by adding "alt+f1 --http_port=80" to user/keydefs.txt, or, if you're on Windows, you could change the port number of an existing Pdplayer instance by using "pdplayer --attach --http_port=80" from the Run dialog.
