Scripting command : export_composition_as
  • Scripting command : export_composition_as
    I am trying to export composition from a pdpcmd file with pdplayer v.1.0.5
    There is a command called "export_composition_as" in the command line documentation but I only managed to open the export dialog box.
    Inside this tutorial below he mention some additional parameters like the name of the file and his path to export it from a command line.
    http://www.digitaltutors.com/tutoria...a-and-Pdplayer
    I was wondering if it was a specific feature of version 1.0.7.6
    Thanks
    Dear Sir,
    Exporting to a .pdpcmd file is available since the original release. In any case since you already have v.1.0.5 you can use your credentials to log in to our web site and download the latest version.
    You should be able to find the option in File>Export Composition as> and then you should see the window that is visible in the attachment.
    Hope that helps
    Best Regards,
    Jimmy
      Thanks for your answer, but my question is about exporting a .pdpcmd file via the command line and not from the menu.
      "--export_composition_as=filename"
      I didn't found it here : http://docs.chaosgroup.com/display/P...mand+Reference
      I want to export after effects script file (jsx) with a command line. Is there another way to do this?
      Thanks again
      Julien
