Actual fullscreen?
  • Actual fullscreen?
    Hi, is it possible to only see your actual sequence when running full screen mode? I'm always stuck with an info bar at the bottom in fullscreen and can't seem to figure out how to remove it.
    You can use the ~ hotkey to remove the info bar.
      does this mean we are to expect some crossover between VRFB and PDPlayer in the near futur? (would be awsome!)
      just a wish, seeing that you know so much
      with due respect of course..
        Hi Vlado! And thanks for your reply.
        I am using a swedish keyboard however , where ~ is a combination of two keys + spacebar when typing. Doing the same thing inside PDPlayer doesn't toggle the info bar. Please advise.
          In that case you could still interact with Pdplayer using only your mouse. Right click on the screen after you have entered Full Screen Mode and uncheck the Information Bar.
          Nikolay Kusht | chaos.com
          Team Lead, 3D Support | contact us
            Nikolay! A thanks to you, and a facepalm to me - thought I tried that already.
            PDPlayer truly is the number one playback software , love the new parallell frame loading!
