Playback Performance Issue on Mac
  • Playback Performance Issue on Mac
    Hi.
    I am normally working on windows and using Pdplayer without issues.
    Now I am working on a MacMachine and Pdplayer is preloading a Sequence fine in RAM, but the fps is only getting up to 3-4 frames a second, when playing back.
    RAM and Machine are fine. Any ideas or tips, how I get Pdplayer to playback in 25fps?
    Thanks in advance,
    Markus
    btw. Mac 10.14.6, Pdplayer 1.0.7.41
    What are the output files and does it happen with other sequences? Seems to be working fine here with a simple test with 55 .EXR frames. Are you sure the frame rate on the mac machine is set to 25.00?
    Nikoleta Garkova | chaos.com
      Hi Nikoleta.
      Thanks for replying.
      I tested with exr files (which are 6k) and also with smaller (HD) jpgs and both cache into RAM and then playback at around 3-4fps. The fps in Pdplayer is set to 25fps (the lower left value right next to the timeline). Is there any other place for setting the fps, I am not aware of?
      Best,
      Markus
