Can you share *.aep and *.nk file, exported from pdplayer compose, showing in docs? Very interesting preedit functions pdplayer for Nuke compose... Only merge in specified order, or time-trimming and time-shifting too?
Export to Nuke and AE
The compositions that were used for the manual are no longer available, but we've placed a sample composition, along with the exported AE .jsx and Nuke .nk files, at
http://www.pdplayer.com/pdpcomp_jsx_nk_sample.zip
Note that depending on where you unzip the file, you may need to edit the paths in the .jsx and .nk files to point at the appropriate location. (It will work as-is if you use C:\ as the root.)
Some questions:
1. loop on some sources not transfered to Nuke script. May be use Retime instead of TimeOffset? But, it is not often event.
2. How exported pdpcomp if sources have great frame numbers. Like cinema-scan?
For example: from 00650120.dpx to 00650191.dpx In Nuke they must be time-offseted to zero in first...
