I've completed the ship tutorial and I'm wanting the rendering of the simulation solution to be shared across my network of 2 PCs.
I believe I need to change the $(scene_dir) Output (Simulation Cache Save Path) and $(same_as_output) Input (Preview & Render Cache Path) paths.
These .aur files are held at this location;
\\i9-7980xe\x\Learning Material\3DS Max\ChaosGroup\Phoenix FD\01 - Ship Tutorial\scenes\001_ship_start.max_Phoenix2_frames \
Yet when I place that into both Input and Output Paths, the previews are no longer there and the renders don't work.....
So, I clicked on the "Reset to Default" for both, thinking that'd fix things, and the preview simulation is still not visible in my scene.
The .aur files are there, nothing has been deleted or moved.
Please can you advise where I am going wrong since surely if I choose Reset to Default, it should at least work again as normal.
I have read the DOCs sections on Input and Output (so I'm clearly missing something !).
Many thanks.![FD Warning.JPG Click image for larger version Name: FD Warning.JPG Views: 1 Size: 45.2 KB ID: 1000354](filedata/fetch?id=1000354&d=1618589228)
Many thanks.
