Default wind ?
  • Default wind ?
    Are there som default wind in phoenix? I have two cannons shooting fire and smoke toward each other. Exact same settings and source, but it´s drifting towards one side every time.
    Well, you can try to debug by urself. Use phx log file. Somewhere here C:\PhoenixFD. Maybe there's some 3dsmax wind here. Or very fast movement or lo spf or old build
    I just can't seem to trust myself
    So what chance does that leave, for anyone else?
    CG Artist
      Can you share your build ID from the About dialogue and your Dynamics settings? Also, please make sure your geometry is simplified and has no open edges or inverted normals.
        Something came in between, will do this tomorrow
          This is weird. The setup was totally mirrored and no setting was changed on one or the other side. complete equal settings. When I opened the scene now to send you the settings i first simulated a few frames. And it simulates perfect now ? totally collision in the middle of the scene. Makes me think that you can update by auto online now ?? What else can have happened ? Am I sleepwalking...haha
            Hmm, do you have two overlapping simulators, or are they separated by some space inbetween?
              Only one simulator
                Roger, if it happens again - please ping us and don't forget your Phoenix version, a shot of the setup and the exact settings that make it happen
                Cheers!
