Emerging object
  • Emerging object
    Hi, I'm trying to learn the workflow for an emerging object from the ocean, want to recreate the rescue of a car from the ocean, is there any actual basic setup scene you can provide? Something simple, just a box.
    Thanks.
    Hello,
    You can select an object and then create an ocean preset from the toolbar, then just move the object a bit down so that it's inside of the simulator and animate it to go up. Start the simulation and you should be good to go.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Thanks a lot georgi.zhekov
