Procedural question: I want to extend a smoke simulation by 50 frames, that has already had a resimulation done on it.
  • Procedural question: I want to extend a smoke simulation by 50 frames, that has already had a resimulation done on it.
    OK, so here is the situation I need help with please:
    I simulated 300 frames - then did a re-simulation to add some extra detail.
    I have already rendered the first 300 frames and cannot re-render.
    I want to simulate an extra 50 frames (and then presumably re-simulate them).
    If I restore my simulation and then extend the first phase simulation, and then re-simulate - will there be subtle differences, or will it just carry on perfectly?
    What would be a good workflow for this?
    Or is the only way this goign to work goign to need re--rendering from the start?
    http://www.jd3d.co.uk - Vray Mentor
    Should work, try it
    Turn off resim, restore the base sim.
    Then enable resim and restore the resim.
    Cheers!
      I noticed an issue that meant I would have to re-render the whole thing anyway (well, I didnt' have to, but... meh) so I thought if I am gonna do it, I'll just re-sim it all... your answer didn't seem convincing enough... although it would be a good case study!
