Making a powder-like look for the simulation
  • Making a powder-like look for the simulation
    Hello Everyone,
    I know that simulating powder isn't really the scope of Phoenix FD, however what I'm trying to simulate is a very fine powder stream, which (from the physics point of view) should act almost identical to a stream of liquid - my main problem is with the overall looks of the final sim. I turned down the surface tension, etc., but I still can't get anywhere near the effect I'm looking for.
    Are there any useful tricks that would let me make the simulation appear more "powdery"?
    Maybe something I could do something about the material of the liquid to make it look more like a powder?
    I'm using PFD for 3dsmax with Vray.
    Hello,
    Can you show us some reference of what you're trying to achieve and the result you're getting?
    Cheers,
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hi Georgi,
      I can't seem to find any good graphic example - imagine a conveying tube that is filled with very fine powder that is moving through this tube - that's called a dense phase conveying during which the powder acts very much like the liquid.
      I was checking the YT for some tutorials and maybe this lava project will be just about what I'm looking for:
      https://www.youtube.com/watch?v=h8tFMswdlpg
      I'd have to remove the splashes a bit and just retain a single color, but it represents quite nicely the 'stream' of what could be dense phase conveyed fine powder - especially with this slightly grainy looks.
      I'll try to check it out and post result.
      For now I was getting something more like the attached picture (although it comes from an earlier and much simpler attempt - I don't have any current result as the sim is still calculating)
        Hey,
        You can check our lava tutorial here - https://docs.chaosgroup.com/display/PHX3MAX/Lava
        Hope this helps.
        Georgi Zhekov
        Chaos
