What's the trick for flowing water along a surface?
  • What's the trick for flowing water along a surface?
    It is better to raise the SPF, but are there any other parameters to keep in mind?
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hey,
    You got it right - more SPF, make sure you have enough grid resolution and probably some surface tension.
    Cheers,
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      thank you for the advice.
      I will try to challenge!
      oakcorp.net
      v-ray.jp
        i would suggest wetting+some stickiness.
        ______________________________________________
        VRScans developer
          Thank you for the advice.
          I'll give it a try.
          oakcorp.net
          v-ray.jp
