Simulation Multiple render nodes
  • Simulation Multiple render nodes
    Is this possible? I'm using backburner but the phonex submit to backburner only creates a single job for a single node.
    Regards
    Steve
    My Portfolio
    Hey,
    There is no distributed simulation yet. It's a tougher problem than distributed rendering since simulation requires non-stop interaction between the different areas in the simulation volume. Having this happen over NUMA nodes on the same motherboard currently slows down the simulation significantly, and having it over a network is much worse. It could be implemented specifically for certain use cases like other software packages do at the moment, but it will not be a complete solution that would work for any scene.
    Cheers!
      Hey,
      Just so we are on the same page - are you asking for creating a separate backburner job for each selected simulator or distributing the one simulation across several machines?
      Cheers,
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
        I was talking about distributing one simulation across several machines.
        Thanks for the info though.
        Regards
        Steve
        My Portfolio
