Can't seem to control the FDFoamTex
  • Can't seem to control the FDFoamTex
    The scene looks odd to me with the small "dots" of foam. These are being created with the FDFoamTex map. I can't seem to get them bigger.
    In the scene, I wanted the waves bigger too, so I adjusted the tiling on the FDOceanTex to 0.35. The scene is to scale, but the ocean waves were too small to look right. I'm not sure if this has anything to do with it, but I thought I'd bring it up.
    Oh yes, this should be fixed in the latest nightly and in the Phoenix 3.99 Beta:
    (*) Foam Texture: Wrong Mapping of the Foam Texture when the Ocean texture used tiling other than 1.0 in World XYZ with 'Use the original non-displaced vertices' [fixed 06 Aug 19]
      I've been having problems with the 3.14 nightly builds. It seems the devs didn't have the same issues, but for some reason, the objects aren't affecting the water as they should for me.
        The only thing I need is a scene that can make the issue happen here, and will be able to solve this issue for you.
          I'm attempting to recreate it.
            I can't get it to happen again. I'm using the same settings and nightly build but now it's working. I did something wrong somewhere I guess.
              Was the foam texture fixed in the Sept 20th build? Or a build coming out tonight?
                The latest nightly build seems to be doing the opposite of what it should be doing.
                  Ah, sorry, I've mislead you - this fix is only in the 3.99 build.
                  You can check easily what is in the nightlies in the nightly changelog zip that comes out with each set of nightly builds - check the zip file here and in all other nightly folders https://nightlies.chaosgroup.com/#/phoenix3max/20190920
                  I will move this change to the 3.15 nightlies and will ping you when it's there.
                    Thank you!
                      Hey, the fix will be in tomorrow's 3.15 nightlies.
