Has anyone gotten Phoenix Birth Flow to Tyflow Actors?
Phoenix to Tyflow Actors?
Here is a basic example file on how this works. I took one of the example scenes from tyFlow and added a Phoenix liquid simulation that affects the actors using the Fluid Force operator.
If you're using Phoenix 4 builds make sure to get the latest version of tyFlow as earlier versions were not compatible with Phoenix 4.
You can take a look at the result here - https://youtu.be/d-Hg0sMzDU0
The scene can be found here - https://drive.google.com/open?id=1Gc...Z4kXP9HSV4Kk8l
The scene is saved for Max 2017 but if you need it for older Max let me know.
Hope this helps!
Cheers!Georgi Zhekov
Phoenix Product Manager
Chaos
