Lava Tutorial
  • Lava Tutorial
    Hello everyone,
    Just wanted to see if we will be getting a tutorial for the Lava simulation in Maya like the one we have for 3DS Max?
    https://docs.chaosgroup.com/display/PHX4MAX/Lava
    Feel like this is a great tutorial that shows a lot of the capabilities of the simulator in one tutorial.
    Hey there,
    sure thing, that's definitely possible although we may tweak things a bit to use the new features in Phoenix FD 4.
    To be fair, the setup in Maya would be pretty much identical so you should be able to follow along using the 3ds Max tutorial. The one key difference that may stumble you is the noise textures - it can get really tough trying to match the noise pattern.
    We also have a Lava example scene for Maya which you may find useful. Here is the link: https://docs.chaosgroup.com/display/...pleScenes-Lava
    Hope that helps!
    gosho.genchev@chaosgroup.com
      Gosho,
      Thanks a lot buddy. Will check this out and follow the Max tutorial. Thank to your team for being so responsive. The community loves you guys and gals.
