Anyone having any luck with Octane 4.0?
  • Anyone having any luck with Octane 4.0?
    Cannot get samples to render. Trying to render the smoke example. Too much diffusion in the Max viewport and a black frame in the Octane viewport. Is there a guide for setting the Octane-volume? The original file rendered without showing any smoke even though the main viewport showed the smoke.
    Hey,
    Looks like that's on the Octane end so it would be best to reach out to the Octane guys.
    Thanks,
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Thanks...Have done
        OctaneVolume says "selected channel not found in simulation data" even though the smoke is visible in the preview
          Sounds like the Octane Volume can't read the channel properly. The people from Octane should be able to tell you more about that.
          Georgi Zhekov
          Chaos
            i reckon try vray GPU, i have found its very fast for smoke stuff
              OOps...I was using PhoenixFD 3.0
