Dynamic Clouds
  • Dynamic Clouds
    https://vimeo.com/391012959
    i dont get it ? is this realtime?
      7 minutes per frame on a GTX 1060
        ok lol very good, check out the hammer chen cloud tut and the jesse pitela training i reckon
          Something I would recommend for removing the banding visible in the very first frames - reduce the Minimum Visible Opacity in the Smoke Opacity rollout: https://docs.chaosgroup.com/display/...+Smoke+Opacity Zeroing it might make the render quite a bit slower, so I suggest you first try reducing it. You might need to edit 3ds Max's preferences so it would allow you to see numbers with more than 3 decimal places though, or it would look as if the number is 0.0.
            Thanks for the tip
