Hey there,
I am not sure if this is a vray or Phoenix question so I will start here. I am revisiting one of my beach wave sims and wanted to explore the workflow I see in a lot of vfx breakdowns. The one where the underlying fluid sim is rendered out, then just the splash and foam layers are rendered out separate and then can be adjusted individually in After Effects (in my case).
I thought it would be a case of rendering the water with the shaders for the foam and splash turned off. I then applied a black override material via vray to cover off the beach and rocks and also applied it to the Phoenix sim but. I then ran a render again with just the splash shader turned on but nothing rendered in frame.
I did this as I have used that when I was mucking around with god rays.. rendered out the scene, then the black overrride and then rendered again with the HDRI enabled and then blended the layers together in PS.
Is there a tutorial somewhere about rendering out various Phoenix FD elements for comping / adjusting colours and such and then putting all the layers down together?
Appreciate the assistance.
S.
S.
