Misty Cloud
  • Misty Cloud
    Hey guys Im trying to make a cloud that is sort of a misty smoke cloud, like the attached photo.
    . Click image for larger version
    I started with the cloud preset and then added some boyancy to the smoke and rotated the wind so it points up a little bit to get the wisps. But the issue I'm having is the geo that I start with gets really dense and all the little tendril wisp parts are very light and faint. When I need them cloud a pretty constant density. Any suggestions on making a misty cloud like this guy?
    Thanks guys!
    Hey,
    You can adjust your smoke opacity in the Volumetric options inside the Rendering rollout.
    You could use a low opacity value or if you switch to the Smoke opacity to be based on the Smoke channel - you can adjust the opacity curve to get the desired result.
    You can also take a look at our cloud tutorial here - https://docs.chaosgroup.com/display/.../Static+Clouds
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
