How to set up a complete cloudy sky?
  • How to set up a complete cloudy sky?
    Hello,
    is it possible with phoenix FD to create a complete cloudy sky or is there anything else recommended?
    I have seen the tutorial for a single cloud, but this is maybe not suitable to build an entire sky.
    My research only led to a Blender plugin, but maybe this could export then VDB to phoenix FD.
    (actually I'm not familiar with blender )
    Thanks for any tips on this
    Hey, there isn't a one click solution to generating whole cloudscapes in Phoenix - there were other topics in the forum where I explained in more detail when you can use different approaches for generating single clouds, such as this approach:
    https://docs.chaosgroup.com/display/.../Static+Clouds
    ... or using the Cloud toolbar preset.
    And after you have generated one cloud or a set of different cloud shapes, you can instance them in the scene manually or using V-Ray instancer and render them out. Note that V-Ray instancer would require rendering in Volumetric Geometry mode.
    Hope this helps get you started in the correct direction, cheers!
      When I move in the IPR through a loaded VDB, then it does not load again.
      So I am quite blind in exploring my scene. It is set on "volumetric geometry"
      Is there a way to go in IPR through the scene?
      Thanks
        Yes indeed, there are issues with IPR not updating in Max.. Are you using V-Ray CPU or GPU? Is there any difference in updates between the two?
