Is motion blur supported with phornix fd liquid when rendered on Vray GPU?
Can you tell us which Phoenix FD build are you using? The information could be found in the Simulation rollout -> About.
Also, can you tell us which V-Ray version you have installed? You can find the V-Ray version in the Render settings window → Settings tab → About V-Ray rollout.
It will be very helpful if you send us a scene that we could use to reproduce the problem.
Thank you!
Slavina Nikolova QA Specialist, V-Ray for SketchUp | V-Ray for Rhino | Phoenix Chaos
We will need more info for that. Do you mean liquids or fire/smoke? Which build are you using?
Can you send over a simple scene, reproducing the issue?
