Falling object melting when it reaches the ground
  • Falling object melting when it reaches the ground
    Hello,
    is it possible to achieve such effect? I need to transform a falling solid object into a liquid as soon as it touches the ground. Something like a melting effect on impact. Right now I'm able to melt a solid object with viscosity but for this task I need the melt process to take into account. the velocity of the falling object too.
      Hey, would this Particle Tuner setup work for you? You have to play with the distance to the floor because if the object is falling too fast, with a low distance it might first land on the floor and then melt.
        Hey Svetlin, I'm testing that with massfx so that the object falls naturally and then melts.I think I'll get back because the whole process is a bit complicated.
