Speed Up Simulation
  • Speed Up Simulation
    Hi all.
    I'm attempting to simulate a jacuzzi. It's only really my 2nd time using Phoenix, my background with fluids is using Reaflow years ago.
    Is there a way to speed up simulations.. For example, in Realflow you used to be able to disable the viewport - that'd speed up the calculations.
    Also, I'm noticing the CPU is only being half used. Is there a way to get max usage.
    Thanks
    I've just put the sim on another system so I can do something else on mine
    This one is using even less CPU and seems to be the same time/frame as my system.
    Also, It has 4 NUMA node entries - mine was greyed out.
    I would have thought the sim would process a lot faster on this other system
    Thanks again
    Click image for larger version  Name:	HEsowD4.png Views:	0 Size:	332.3 KB ID:	1107787
      Hey,
      You can disable the preview during simulation from the Preview rollout and this should speed things up. You can find more about it here - https://docs.chaosgroup.com/display/...Liquid+Preview
      As for the Numa machine - unfortunately NUMA and multiprocessor architectures do not perform well with Phoenix. Simulating on one NUMA node is often faster than waiting for multiple nodes to synchronize.
      You can check our hardware recommendations here - https://docs.chaosgroup.com/display/...sterSimulating
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
        Ok, thanks for the reply... So, how do you recommend I sort this?
        Do I select 1 node? For example, Node 0. Do I do something with the thread limit option? Or a combination of both ?
        I'm hesitant abt doing anything until I hear back from you because I don't want to risk messing up the current sim.
        I'd assume that anything I need to do I'd have to stop the sim first, do something from above..... then restore the sim
        Thanks again
          Hey,
          Yes. You can stop the sim, select one of the Numa nodes, either one should be fine.
          Then just restore the sim from the last frame.
          Another tip that you can use depending on the scene you're making (you can shrink the grid on one of the axis so it becomes narrower) - this way you would be able to iterate faster the behavior of your liquid. Obviously this would work only in certain cases but it is worth mentioning.
          Georgi Zhekov
          Chaos
            I'll give it a whirl.... thanks again
              Hmmmmmm. If anything that's made it worse.
              It's now added on 5-6 extra secs per frame and the cpu usage has dropped a bit too.
              Just selected all of the NUMA nodes and it's back to being faster by 5-6 secs per frame.
              Weird.. Thanks anyway.
                Hey, can you also check how quickly today's nightlies will simulate for you? https://nightlies.chaosgroup.com/#/p...ghtly/20210318
                I did some small changes the other day so they might be of some benefit....
                  Thanks. I'll try to give that a try
                  Sorry for the constant questions..... which one should I use? We don't use Vray. Would I need to install this on all systems or just the one in question?
                  Will this cause issues with rendering on multiple systems?
                  If things don't work out I assume I need to uninstall and reinstall the phoenix version we're currently using
                    Ah, if you are not using V-Ray then it does not matter which one you install - these need to match the V-Ray version only if you do use V-Ray.
