Unhandled exception
  • Unhandled exception
    I made a scene follow the tutorial 'Ship in the ocean', then something happened.
    Any reply can be appreciated, thanks.
    Hey,
    Could you give us more information about your scene and settings?
    Could you tell us which are your exact Phoenix and V-Ray versions?
    In order to find out the exact Phoenix version you can check the About info window. 3ds Max/Maya → Top 3ds Max/Maya Phoenix FD Menu → About Phoenix.
    You can find the V-Ray version in the Render settings window → Settings tab → About V-Ray rollout.
    Thanks!
    Slavina Nikolova
    Phoenix QA Specialist
    Chaos
      Originally posted by slavina.nikolova View Post
      Hey,
      Thanks!
      My Phoenix version is 4.410, Vray version is 5.10.2
      I just follow the 'Ship in the Ocean' tutorial: Ship in the Ocean - Phoenix FD 4 for 3ds Max - Chaos Help (chaosgroup.com)
      It's OK when I only set about 7-8 simulators in the scene yesterday, it can be rendered well, but not now.
      I copy PhoenixFDLiquid simulators up to almost 50 which all with ocean mesh mode, then it showed me that threat warning.
        We reproduced it on our side, thanks for the report. We will update the thread when we have more information on it.
        Thanks!
        Slavina Nikolova
        Chaos
          Hey, we fixed it!
          The fix will be in 19 Jun's nightly builds here: https://nightlies.chaosgroup.com/#/phoenix4max/nightly
          Thank you so much for reporting this issue!
          Cheers!
          Svetlin Nikolov, Ex Lead Phoenix developer
