Subframe smoke issues
  • Subframe smoke issues
    I have a moving object that is releasing smoke over small period of time. The problem is that the smoke emits per frame and you can see gaps between the emissions. Is there any way to increase sub-frames so that there is a continuous stream of emission?
    Regards
    Steve
    My Portfolio
    Hey,
    How about if you increase the Steps per frame in the Dynamics rollout?
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hi. I tried increasing the steps per frame in Transport (advection) and although the simulation looked better it didn't resolve the gaps between emission frames.
      Regards
      Steve
      My Portfolio
        Can you show us how it looks and the settings you're using?
        Georgi Zhekov
        Chaos
          Hey there. Here are the screenshots.
          Regards
          Steve
          My Portfolio
            The capsule separates over 5 frames which I realise isn't a large amount of time but it's causing issues like gaps in the smoke emission.
            Regards
            Steve
            My Portfolio
              How about if you set the steps per frame to 10 for example or even higher? Looks like the capsule is moving way too fast.
              Georgi Zhekov
              Chaos
                I think that's working. 6 subframes wasn't enough but 10 seems good. Thank you
                Regards
                Steve
                My Portfolio
