Export alembic
  • Export alembic
    Hi there,
    i have to Export a Liquid Simulation included foam.
    wondering whats the best way for it.
    Its going into Cinema4d and Renderd with redshift i think.
    Is alembic the way, Even for foam particles?
    thx and best regards
    jonas
    Jonas
    www.jonas-balzer.de
    www.shack.de
    Hey,
    For renderers other than V-Ray, ABC sounds like the best option. Not sure if Redshift can import PRT caches which Phoenix can also export, or if it can read points from VDB files: https://docs.chaosgroup.com/display/.../Liquid+Export
    Cheers!
      hey Svetlin, sorry i didn't answered.. totaly got out of my mind..
      For now it seems that i have to render the scene by myself. It's a 400 frames camera fly-over an ocean, and a short 40 frames simulation of an object falling into the Water at the end.
      the Pure Ocean Displaced by texture looking quite good, but how could i handle it that I'am only simulate the last 40 frames? for now the Ocean only comes visible as soon as i simulate the last frames.
      Do i have to handle it over cascade, one with pure ocean and the other with the simulated part?
      Thanks and best regards Jonas
      Jonas
      www.jonas-balzer.de
      www.shack.de
        Ah, pure ocean will ignore the simulation shape and will not read the simulation caches at all.
        Would it be easier if you enable Load Nearest If Missing? This way it should show the ocean in all frames of the pre-roll.
          Yes!! thats it. Thanks mate!!
          Jonas
          www.jonas-balzer.de
          www.shack.de
            Woohoo! Cheers
              Hey Svetlin, smt weird is going on here.. is the ocean generated even if its only visible in reflection? It llooks like only the part wich is in camera is only visible in reflection too? and somehow it seems like the ocean din't get the material in reflection too.. Only the simulated part seems right as you can see here.
              Jonas
              www.jonas-balzer.de
              www.shack.de
                Hey,
                The ocean is indeed generated only in the camera view. In order to expand it you can use the Offscreen Margin option. You can find more about it here - https://docs.chaosgroup.com/display/...endering-Ocean
                Cheers!
                Georgi Zhekov
                Phoenix Product Manager
                Chaos
                  i see. Thnx. Seems to overkill my workstation though.. i wan't come even close to the area i need. I'll see how i can split the rendering maybe.
                  thanks again for your help
                  Jonas
                  www.jonas-balzer.de
                  www.shack.de
