emit presimmed pfd boxes as particles
  • emit presimmed pfd boxes as particles
    How would one emit one or more PFD sim boxes as many particles? Using Tyflow is preferable, but could use Pflow as a backup. Just need a way to control timing and placement of a bunch of presimmed dust blasts, and randomize the rotation and have frame 1 start at the particle's birth. Seems easy enough, but not finding any way to do this. Thoughts?
    Example would be if one has a bunch of dust bursts for bullet hits and then just want to place them when a machine gun is shooting all over the ground in a wide area.
    Thanks in advance.
    Aha, you mean instancing simulators over particles with offset starting frame? This can't happen currently I think... If this is what you need, will log it in the to-do list.
      Yes, exactly that. Would be great to have! Thanks!
      Got a response over at Tyflow forum but I'm not sure how to do it with Ty Script.
        My colleagues have been looking at the tyflow solution for the last two days and will ping you with more info
          Hey,
          Here is a sample scene that shows how this works. It is saved for Max 2019, let me know if you need it for an older version.
          I'm attaching and a screenshot of how the MaxScript in the Export Particles operator should look like.
          tfObj.inpoffset stands for the Phoenix simulator's cache origin option in the Input rollout.
          tfTime*(-1) will get the current time when the particle is born and will multiply it by minus 1 so the value will be negative.
          So essentially what will happen is when a particle is born we will offset the Cache origin of the simulator.
          The other important option is to Enable the auto export on render - this way you won't have to fill your scene with copies of the simulator and slow the viewport performance.
          Hope this helps, a bit later I will record a video that goes through the steps of setting up the scene.
          Georgi Zhekov
          Phoenix Product Manager
          Chaos
            Fantastic! Going to try this out. Thanks so much!
              Works great - thanks a boatload!
                And here is a video that goes over the steps
                https://youtu.be/xQ3x9es4xY8
                Cheers!
                Georgi Zhekov
                Chaos
