Hello,
I have a river setup, where I am testing a cascade setup now.
- is it correct, that I just have to duplicate the simulator and "reset the output to default" and can already use it as a cascade?
I will need it only for rendering.
And I would have to start the simulation from the second (later) simulator, in order to get both working)
- for compositing: would it be possible to render each simulator without the other? (to assemble them only later)
- looping simulation: Is that also with a cascade setup possible?
- I read now also, that it does not speed up the workflow with liquids?
(if not which sense has it then?)
Thanks
Thanks
