Grid expansion - possible to set the grid "pivot" (in which direction it is expanded)
  • Grid expansion - possible to set the grid "pivot" (in which direction it is expanded)
    Hello,
    I wonder, if there is something like a pivot, to expand the simulation grid.
    When I adjust the Z size (in order to get fast falling liquid better), it's expanding to the top and not to the bottom.
    So it forces me to redo my simulation, when I would like to adjust the grid manually.
    Adjusting the 3ds Max pivot did not have any effect.
    Thanks
    Yes, the origin of the grid is always fixed to the middle of the bottom of the box. If you know you need to size it both up and down, you could rotate the grid to the side, no?
