Volume Grid VDB export to realtime viewer like Sketchfab
  • Volume Grid VDB export to realtime viewer like Sketchfab
    Hello,
    I was wondering if a simulated VDB file from Phoenix FD (one frame volume grid) can be exported to a Realtime 3d viewer like Sketchfab. If so is there a file format that supports .VDB like .FBX or some other format?
    Thank you,
    C.
    Hey,
    The VDB format is quite universal, so if the viewer or the application supports reading vdbs - it should be working with vdb files exported from Phoenix.
    Cheers!
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      cmeusy , does Sketchfab support volumes though?
      Also, sorry if I'm pointing out the obvious, but does the Phoenix Standalone Preview work for you (https://docs.chaos.com/display/PHX4M...ne+Previewer)? What is your workflow?
        Hello Svetlin / Georgi,
        Not familiar with the previewer, I will look at that more carefully thank you.
        No Sketchfab does not seem to support volumes. However people are somehow slicing the voxel grid and applying a texture for that slice in XYZ. Seems like a tedious process to do manually.
        But I would love to show off some Phoenix FD smoke/fire/explosions (Single frame) in a real time format like Marmoset Toolbag or Sketchfab online.
        Attached is an example. The model viewer shows the grid construction.
        https://sketchfab.com/3d-models/fluf...9d2ea39eff74d1
        The alternative I guess is converting the volume into a mesh, but how do I get a UVW texture projection onto the mesh?
        https://sketchfab.com/3d-models/expl...2fec5f5556a621
        I know this is a bit outside the scope of Phoenix, but it would be good to know of a way to export this into another real-time viewable format.
        Thank you for reading.
        Cyril
          Ahuuuum, looks like a lot of manual work if these were done manually. I wonder how we could make this conversion to a mesh more automatic somehow...
