2d simulation
  • 2d simulation
    Hi.
    I've read in doc that 2d simulation is possible. I'm having issues with grid size set to 1. WIth relatively low number like 6 I can see the smoke coming out of the source. With lower number it simply doesn't show at all. I even tried with very small source that would fit in that 1 sized slice to no avail.
    Any idea how to set it up?
    Thanks
    Hey,
    Could it be that your emitter object is too small while your grid resolution is not high enough? Does it help if you increase your grid resolution a few times or if you use a larger emitter?
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
