Should I be using Meters or Centimeters for larger scale sims in Maya Phoenix?
Meters and Centimeters
Whatever works best for you - you can adjust how the simulation will behave using the Scene scale option in the Grid rollout.
If your scene is structured in a way that makes it hard for you to scale the objects to their real-world size, you can use the Scene Scale parameter to tell Phoenix to treat the container as larger / smaller than it actually is when measured in Scene Units. This will influence the dynamics of the simulation, allowing to you achieve the correct behavior for your simulation without the need to tweak the size of the objects in your scene.Georgi Zhekov
Phoenix Product Manager
Chaos
- Likes 1
