I have a current simulation that has a power boat moving along it. I wish to animate the rotor wash of a helicopter travelling nearby and then combine these ocean meshes. Firstly, any tips on creating the rotor wash and secondly can you combine two ocean sims together?
Rotor wash over ocean and two sim ocean meshes combined - possible?
good morning Steve,
my assumption, it can work.
You can combine two or more grids with the ocean surface.
Take a look here in the docs:
https://docs.chaos.com/display/PHX4M...p+in+the+Ocean
At the very bottom of the tutorial, it's explained how to combine.
For the rotorwash, ironically, just watched Zdravko Pavlov dabbling with it, maybe reach out to him to make a great rotorwash
https://www.youtube.com/watch?v=aIfibUmZFls
Hope that helps as a start!
have a great sunday
Olika mentioned it but here is a scene, along with a bit more info from Zdravko Pavlov on how you can approach it here - https://youtu.be/-ZhdAJT-jHs?si=3CiU98Mb-RNGTTJOGeorgi Zhekov
Phoenix Product Manager
Chaos
Yes, thank you. I was linked to this scene. Very useful!
Rather than start a new thread I wonder if you can help me out with the phoenixfd scene that Zdravko Pavlov provided. I merged it into my scene and then got confused! Link to his scene here: https://www.youtube.com/watch?v=-Zhd...=ZdravkoPavlov
When I merged the setup into my scene I had to increase the grid size for the draft to match my scene and helicopter scale. I also had to scale up the geometry that the velocity information was emitted. I made sure my ocean was only responding to the PHXmapper velocities.
I have managed to run the draft sim to create the velocities which look okay for now. The problem is that the FDTexmap doesn't seem to be interpreting things correctly. Originally it was set to tiling mode: Single clamped. I cannot seem to get the velocities to work correctly. I think it may be to do with the tiling mode or color scale. It just creates foam in the wrong places and doesn't have the same effect that the original Zdravko scene provided.
Can you help me out?
Originally posted by zdravko_pavlov1 View PostHi, Steve.
If you can send me a simplified version of your setup, I can take a look and try to figure out what isn't working. Or, if that's not possible, can you please take a few screenshots of the settings.
ThanksI'm currently trying to save files from a failing hard drive but will upload a simplified version asap. Cheers
