Using Ocean sim as a cutter object for Volume Grid
  • Using Ocean sim as a cutter object for Volume Grid
    could be there some way how to use Ocean sim as a cutter object for Volume Grid? Because ocean geo its just a displaced plane it doesnt work as a cutter object well, but maybe someone knows some way?
    Thanks
    You could switch the mode to mesh and then extrude it so you got a closed volume and use it as a cutter object...
      but this require to have two ocean sim pools :/
        export it as .abc?
          Hello,
          The cutter geometry needs to be a closed object and the ocean surface isn't.
          1. Exporting a standard mesh in Mesh Mode as alembic and using it as a cutter will work, yes.
          2. You can also copy the simulation. Make it non-renderable and switch it to normal mesh. Use it as a cutter. Leave the original, renderable copy as ocean surface.
          3. Use TyMesher to mesh the liquid particles as a closed object and use that as a cutter instead.
          Hope that helps. Cheers!
            Thanks ill see what i can do.
              So in the end best way is to use distance texture pluged to smoke opacity with modulate on.
