Creamy type foam
  • Creamy type foam
    I'm trying to create a foam/cream mixture using phoenix. I am currently using the phoenixFD particle shader and not able to get these types of results. Does anyone have any guidance or ideas on how to best recreate this type of look?
ID:	1228655Click image for larger version
    Regards
    Steve
    My Portfolio
    Hey Steve,
    This will be quite slow to render if you go only with using particles - maybe a mix of liquid and particles will do the job - can you show us your results along with your settings so that we can give some advice?
    Also in some of the references the bubbles are stretched - I'm afraid this is still not possible with Phoenix, the bubbles will remain spherical.
    Thanks!
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Not exactly the same look, but it might be useful - https://youtu.be/OfcgSU-a0ds?si=ZxZ0ZfJdeDMgiWPe
      Georgi Zhekov
      Chaos
        Thanks Georgi. This was the tutorial that I used to get a starting point. It needed post work though to get that creamy type look.
        Regards
        Steve
        My Portfolio
