Phoenix cpu usage and network calcs
  • Phoenix cpu usage and network calcs
    So am I right in thinking that this isnt implemented at the moment. Im only using 25% processor power on a 4 core machine...also I cant set up network calcs for the sim ?
    Seems to me something that this programme is crying out for on both accounts !!
    Regards
    Steve
    My Portfolio
    really, the network simulations are not available at the moment
    about the CPU - the simulation is multi threaded, but the interaction with the scene is not. "pure" simulation, without animated/moving objects should reach about 60% with the current version, and about 70-80% with the incoming service pack
    ______________________________________________
    VRScans developer
      Ok thats good news. Do you think sims with moving objects and networking calcs will be something that will come ?
      Also, how long until the sp ?
      Regards
      Steve
      My Portfolio
        well, the networking is really a complex task, because the simulation (unlike the rendering) has each-to-each dependence of the all the grid cells.
        about the interaction with the max scene - some parts can be accelerated, but some parts are hanging on the max and we can do nothing. at the moment the most expensive operation is the applying of a space warp force.
        regards,
        ivo
        VRScans developer
          ok. well, at least there will be performace increase when the sp comes out. Most of the sims im trying to do with Phoenix are object animated so that would really make a difference.
          Regards
          Steve
          My Portfolio
            Would it be a possibility to have special warps for phoenix use that are multithreaded eventually ?
            Regards,
            Thorsten
              technically is not a problem, bot is a lot of work. another option is to overwrite the existing ones and to use only their UI parameters.
              VRScans developer
