Particle source size
  • Particle source size
    Is there a way to control the size of the particles for emission in the grid? They seem to change size with the Cell size, particle size = cell size.
    It would be good to have control over this either directly in the particle system or as part of the Phoenix Source
    Jordan Walsh
    Senior FX artist
    Showreel 2010 (new)
    Check out my scripts at Script Spot!
    this is already implemented, but will be available in the next update.
    ______________________________________________
    VRScans developer
      excellent
      May I ask how it will be implemented?
      Jordan Walsh
      Senior FX artist
      Showreel 2010 (new)
        there is a size parameter in the "shape" operator of PF (if i'm not wrong) and it afects the size. in general there is a way to ask any particle in the max fot its size, and this method is used, so it should work with any particle system supporting size, not only PF.
        VRScans developer
          Would the scale of the particle then modify this size? I mention this as most of the time scale is used to add variation to the size parameter. I almost never have a pFlow that uses only "size" to define the resulting size of a particle.
          Jordan Walsh
          Senior FX artist
          Showreel 2010 (new)
