easy way to drop a volume of fluid?
  • easy way to drop a volume of fluid?
    is there one?
    i don't mean pre-filled scripted grid cells
    but rather a custom object (volume)
    thanks!
    Keep Going!
    put the object in the exclude list, and make it a brush mode source (see the non solid options of the barrel). set the discharge to be 100 in the first frame and zero after that.
    ______________________________________________
    VRScans developer
      cool i'll try that
      would be a good trick for the manual unless i missed it, and it's already there
      does the 100 mean percentage of fill?
      and why brushed? what if i have a regular full sphere to drop, wouldn't it have to be injected?
      i'm a bit confused ...
      BTW "brushed" and "injected" sounds great (if you're in a doctor's office, no guessing what's going to happen next ...), but "surface" and "volume" is easier on the eyes and more appropriate in a context of 3d
      also there is an undocumented "inject mode" check-box in the dynamics roll-out under randomize, what does it do?
      Keep Going!
        actually this is one more reason to split off fluid UI, so you can allow a volume drop in a more intuitive mode, may be by something like setting emission to "volume" and discharge to 0
        Keep Going!
          yes, something like that. 100 means immediately. 50 means that for one second it will be at 50%, but for two seconds will be not 100%, but 75%. every second it fills the *rest* by this percentage.
          brushed and injected is not surface and volume. the brush works like the brush in the photoshop - the longer you use it, the bigger is the affect, approaching 100%. the inject mode creates new fluid in the affected volume causing expansion. both of them affect the volume, not the surface.
          VRScans developer
            ... ehhh, i see ... i take it makes some sort of difference in your algorithms ... but what's the practical difference in terms of fluids?
            cause in real life it's either a filled volume being poured somewhere or a prolonged flow, which could be approximated to a surface sweating at a certain rate, for fluid simulations at least
            i'm starting to think Phoenix is crazy enough to produce raining clouds all by means of simulation ...
            Keep Going!
              in fume fx the brush mode is called "free flow" as i remember. in general to find the perfect name of such a parameter is not easy task
              VRScans developer
                Ivaylo, i've tried the suggested method of dropping a volume and ... instead of the volume it drops a bunch of metaballs (droplets) that are spaced apart so far that when they finally all blend together i get about 20 % or less of the volume i started with. Any suggestions?
                BTW this is a real project scenario, i'm trying tio simulate the waterfall with a pond below it.
                In RF (hybrido) i've dropped the prefill for the pond, then ran an untimed sim until i got the pond settled and the waterfall flowing at the desired rate an then turned on the timeline. Nice and easy.
                Now i'm looking for ways to do the same in phoenix. The pond basin is irregularly shaped so i'm not sure i can prefill it with the grid somehow ...
                thanks!
                Keep Going!
                  my bad i was injecting instead of brushing, will keep you posted on the progress ...
                  Keep Going!
                    everything seems to be working ... except for may be too much "tearing" in the fluid mesh
                    not sure how to fix it
                    the tearing pattern appears to be relevant to the grid resolution
                    so, i'm guessing a finer grid might fix it
                    the only problem is i'm already at 3million cells
                    Keep Going!
                      can you post an image?
                      VRScans developer
                        i think i already erased the cache ...
                        i'll check when i get home
                        in any case i'll continue experimenting on the file and if it comes up again i'll post
                        i did get a couple of splashes explosions with water disappearing
                        so far comparing it with a very similar simulation in RF, phoenix seems faster
                        it's not an apples to apples comparison though, too many things differ between the solvers
                        getting some help with loading a solution frame through script into initial state would be very appreciated
                        regarding this, say i'm running the pond under the waterfall first to make it settle (splashes are turned off) "sim1"
                        once it appears stable i want to start the steam flow to create the waterfall above ( this time splashes are on) "sim2"
                        i also need to wait till the flow to the waterfall is fully established (as for the render part i need a fully running waterfall) "sim3, render output"
                        how would you recommend to go about switching from simulation to simulation?
                        to give you an example for RF 1. i run untimed water drop for the pond fill, 2. once settled i run untimed flow. 3 once a good amount is pouring down i start recording the simulation frames for the output into meshes
                        and another question: what do do i need to do to stop water from growing? you've mentioned there is a way
                        thanks!
                        Keep Going!
                          i'm seeing some the answers in the beer thread, i'll try those
                          Keep Going!
                            trying the grid fill to fill up a volume inside by letting the exess fluid fall down
                            on the pool scene i'm getting strange results, the is no visible cells on the sides of the solver, but it still renders "aquarium" walls
                            Keep Going!
                            • #15
                              as i see, the preview is adjusted to show only the water-air interface (range 0.1-0.5), not the pure liquid. the "aquarium" is pure liquid with value of 1 and is not visible in the preview. you can change the initialization script to skip the walls, or to enable the wetting and to set some very small druing time.
                              until the "official" initial load you can use the restore function, renaming the desired cache to correspond to the cache names of the simulator that will use it to initialize. about the untimed sims, well you have to run them timed here or i'm missing some very important reason why they should be untimed?
                              play with the surface balance parameter.
                              VRScans developer
