For those who own sandy bridge systems
  • For those who own sandy bridge systems
    If you encounter huge problems with phoenix stability - check your ram. If it passes linx 0.6.4 AVX edition - then it is fine, otherwise it's ur ram fault
    I'm now using sandy bridge @4.5ghz and it was my ram lower than stock voltage (1.6 vs 1.65 Corsair XMS3) that created some false alarms to Ivaylo
    Just FYI.
    P.S. Phoenix can be a RAM stability test
    I just can't seem to trust myself
    So what chance does that leave, for anyone else?
    CG Artist
    thanks for the hint...unfortunatelly i cannot set my ram to 1.65, cos its not in the menu :-/...shoul i set it to 1.66???
    Martin
    http://www.pixelbox.cz
      Well, there's more news - it was also a faulty memory module
      No. You shouldn't go beyound ur stock voltage. My stock voltage for xms3 is 1.65
      CG Artist
