smoothing the fluid and freezing the fire
  • smoothing the fluid and freezing the fire
    Ivaylo, what's the best way to smooth the grid stepping artifacts in the fluid?
    And how do i freeze a fire sim to show 1 sim frame through the entire timeline? So far the best i was able to get is some kind of double stacked effect where the playing full sim is still there, but the frozen frame is also present. (this is on 1.2)
    thanks!
    Keep Going!
    there was a tutorial on freezing time (and freezing the flame into ice)
      there are two types of these artifacts
      - on the liquid-geometry interface, use the gizmo option
      - on the liquid-air interface, decrease the sharpness, or static surface correction, if the liquid is near to settled state
      the best way is to animate the simulation timescale, like in the "freezing flame" scene. however, if the simulation is already done, you can use the input control that provides two different approaches:
      - animated play speed
      - animated frame number
      keep in mind that if you use the input tools the intermediate frames will be generated using interpolation. this can lead to clearly visible artifacts when the play speed is too low, that's why i would recommend to use the simulation time scale not the input tools.
      ______________________________________________
      VRScans developer
        what do you mean by "decrease the sharpness"?
        i don't see any controls named "sharpness" or anything similar ....
        jitter and soft boundaries don't seem to matter for fluids, as far as i can tell, any number i try produces exactly the same rendering
        Keep Going!
          the sharpness parameter is in the place of the old "approach steps" parameter.
          VRScans developer
            Hi
            Liquids rollout -> Sharpness(approach steps)
              should say that the difference is more than the name
              VRScans developer
                ok thanks!
                mine still says "approach steps"
                time to get a newer version i guess
                Keep Going!
                  yes, it's time
                  btw the rise/boiling is fixed, i remember that you had problems with it.
                  VRScans developer
                    Originally posted by Ivaylo Katev View Post
                    yes, it's time
                    can you elaborate on that a little
                    i got the new one and it does look a bit different
                    the surface correction hack missing for one
                    so, was there really a bug in there somewhere?
                    and what should we expect now that it's gone ... hopefully
                    did all advection methods become more stable?
                    cause you are saying rising AND boiling and those belong to Classic and Forward transfer respectively
                    thanks!!!
                    Keep Going!
                      you mean the surface tension? it is removed from the UI only, because is not stable enough.if one needs it the listener can be used.
                      the advection methods are not changed, they were stable and work fine. actually the conservation was the guilty one and unfortunatelly the fix affects all the simulations. seems like you have no access to the beta forum did you? there was a message about the last beta update
                      VRScans developer
                        beta forum? what's that?
                        i just had an interesting sim last night
                        everything was running fine for a while with fluid and splashes and then in the course of 3-4 frames i got myself an .... eehhh ... an explosion at a noodle factory
                        splashes flying in ray beams everywhere!
                        it's a cool effect, but max of course didn't appreciate it at all
                        Keep Going!
                          bidirectional conservation? i'm about to remove it from the UI too
                          VRScans developer
                            nope
                            smooth
                            i tried to continue from the last good frame and it kept crashing in about the same timeframe
                            no special effects though just pain old crash, i think with a memory leak
                            turning off the splashes allowed me to keep calculating, but it took all the fun out of it
                            a was running forward transfer if that matters ...
                            Keep Going!
                            • #15
                              yes, we have already reports about the crash problem, but the explosion is disturbing. did you use the "affect liquid" option?
                              VRScans developer
