Image Dissolution
  • Image Dissolution
    Is there a way to map an image to smoke, foam or liquid directly in Phoenix?
    not sure how to understand the question. the smoke shader has texture slots, the liquid uses the assigned material, the foam does not have mapping, except those used for coloring.
    ______________________________________________
    VRScans developer
      Liquid doesn't seem to be mapped. by image I meant a picture that melts or blows away.
        so a way to use camera mapping onto the smoke at a specified frame then the smoke dissipates along with the image
          what you are trying to achieve?
          VRScans developer
            VRScans developer
              I'm trying to decide if I need to buy Krakatoa.
                You can get trial license. But, don't forget, that particles, generated by phx are quite xpensive, in terms of hdd space
                Direct conversion of grid to krakatoa particles is not possible. For now.
                I just can't seem to trust myself
                So what chance does that leave, for anyone else?
                CG Artist
                  Did you generate your incredible example with a PhoenixFD birth in pF?
                    Nop. Just phx particles. Check PHXSource particles. You should monitor the amount via the input panel.
                    CG Artist
                      Thanks Paul. I tried to modify the multicolor sample, but the smoke turns to white.
                        How does one invoke the PHXmapper?
                          as the other objects, it works by default.
                          VRScans developer
                            What if there are 2 sims running?
                            • #15
                              affects the both of them
                              VRScans developer
