Smoke out windows
You might have to decrease vorticity a lot, like into 0,25-0,5, assuming your box is in meter scale. this would prevent dissipation.
Also try to decrease SPF upper limit somewhere between 3-6.
Hope this helps a bit.
EDIT: I think you have too big grid box for the current resolution. I might try to increase cell size and use adaptive grid box. It helps to simulate much faster the first frames and let you see is the smoke moving through the window as wanted.Last edited by TSR_trix; 28-03-2013, 11:53 AM.
@trix: decreasing the vorticity didn't see much change, but decreasing the SPF upper limit to 5 was good.
@ivo: i think it will be okay without changing conservation past 8
Also I shrunk the interior of the room down quite a bit to help push it out, and then I used a lower temperature (around 1000) for smoke. It seemed to work for the situation.
Thank you guys a bunch for the help!
