So I'm a brand new Phoenix user and was a little scared after buying and then finding some issues, but at this point I'm actually very happy with it!
I do seem to be having an issue with thin geometry though. See image:
You can see I'm doing a sort of water wall or waterfall effect and I noticed the fluid didn't seem to be interacting with the thin panels (I smeared the panel profile because I'm not really supposed to share). So I put a big box in the flow to make sure it was interacting with objects correctly and it behaved as expected. So then I put a thin box in the flow next to it and you can see the fluid passed through it.
Is there a setting I'm missing? Does the grid have to be smaller than the thinnest geometry? I hope not!
The scene is scaled correctly and the units are setup the same as the scene scale etc. Below are the settings:
Thanks!
Thanks!
