pushing liquid through pipe with mesh
  • pushing liquid through pipe with mesh
    i'm trying to push liquid through a pipe with a box, but can't seem to get the collisions right, it seems ok for a few frames then explodes or shoots out behind the box
    i'm using the liquid preset and set advection to forward transfer, upped max step to 1000 and SPF upper/lower to 32/8, no go
    is there some trick that can be done with this kind of scenario?
    advstep=1000
    min/maxspf=1 , may be more if the box is quick
    conservation smooth, 100 or more. this is the most important parameter for the pressure based effects. if my suggestion does not work, send us the scene
    ______________________________________________
    VRScans developer
      thanks ivaylo, i tried and failed but sent you a PM
