Timescale
  • Timescale
    Hi.
    I have a simple question but the "Help" in Phoenix FD Spot 3D does not seem to cover this in any detail.
    When I create a simulation and use "Time scale" in the Dynamics options (e.g. Time scale = 0.5 to slow simulation to half speed), I need to simulate to see the results, then make any changes and simulate again.
    Is it a more sensible method to simulate at Time scale =1 then use "Play speed" on the Input options to test at different speeds?
    Thanks,
    T
    play speed and time scale do not have equal effect. the play speed uses interpolation to reconstruct a frame between two key frames, that is not real and works worse than the original time scale during the simulation.
    ______________________________________________
    VRScans developer
      OK, thanks Ivaylo.
