Add more Target Objects at once
  • Add more Target Objects at once
    Hey,
    I was wondering whether there's an option to add a group of Object instead of picking each single object as a Target Source Object. Because I'm trying to emit smoke from a Fractured Object and it's a bit annoying to add each part for itself.
    Thank you for your help!
    we are using the standard UI components of 3d max, and we can't modify them without huge efforts, but fortunately this functionality is supported by default.
    when you pick the add button open the "select by name" tool, you will see the list of the available object. press the ctrl key and click over the objects that you want to add in the list.
    ______________________________________________
    VRScans developer
