foam / bubbes to walls. And difference of mesh types (maya, phoenix2.2)
  • foam / bubbes to walls. And difference of mesh types (maya, phoenix2.2)
    Is there a way to make foam bubbles stick/attract to walls like in the picture bellow?
    http://images.wisegeek.com/glass-of-orange-juice.jpg
    When I simulate they tend to stick together in center and form a center blob? Any pointers on how to do this if it´s possible? Scripting?
    Attached sim;
    blast13.zip
    Also wondering what the difference between solid, static and dynamic meshing under render mode is?
    -e
    we have an option called "sticky" in the foam panel, but it can't produce the same effect. it makes the bubbles to stick to the walls, however in your case this is not enough, actually the bubbles are attracted by complex surface tension forces to the walls.
    ______________________________________________
    VRScans developer
