Phoenix and Maya 2015 - Viewport 2
  • Phoenix and Maya 2015 - Viewport 2
    Is there a limitation with Phoenix and Maya 2015 in the viewport?
    I tried to create a fluid sim but it did work. I had to switch the viewport to the default (it is now VP2 by default) in order for Phoenix to work.
    Thanks,
    Yannick
    It's a known bug which which will be fixed in the future builds.
    As you've already found it you have to switch to Legacy Viewports right now wince VP2 is not supported.
      Only the interactive placing is bugged, you can also disable it and work in VP 2.0
        Thanks for the bug confirmation.
        It seems that only the placement doesn't work. It worked back in VP2 once created.
        Cheers,
        Yannick
