ancient ship
  • ancient ship
    hello
    i have an ancient Greek ship which its speed obviously is slow like 7 knots, so i don't have much interaction with the water, weak waves not much
    splashes and foam, how could i increase the whole effect? The size is realistic and the units in cm.
    thank you in advance
    andrew helmis
    well, interesting question, my first reaction was to recommend the velocity multiplier, it does exactly what you need, but if you use the moving container technique, the ship is technically not moving and the parameter will not work.
    hopefully we can change this and you can use nightly builds with the above mentioned solution.
    ______________________________________________
    VRScans developer
      ancientShip
      Ok thank you, one certain reason is that the sea is always calm, with a wave generator during sim will create additional waves, splashes etc, hope will be added
      thanks
